Author Topic: Sunset 4 cylinder rules ?  (Read 2296 times)
Offline Pinecrest
  • King of Canadian Racing Online
« on: December 05, 2006, 04:46:31 PM »
Having to leave after the Late Model  rules meeting could someone pass a long what if any changes were made to the lower two classes ?
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=5682.msg21961#msg21961
The opinions expressed here are mine and not necessarily those of CRO or its other members , but should be .
Offline Doherty
    • http://racechaser.cjb.net
« Reply #1 on: December 05, 2006, 05:35:18 PM »
Thunder cars nothing really changed...they will be on the Hoosier or the Towel City recap the same one barrie is now going to. Tubular Upper Control arms are now permitted and no e-vac exaust system allowed.
Four Cylinders-Sunset Reserves the right to add any amount of weight required to any location, alter percentages or install a rev limiters on any car deepmed to be to fast in order to keep this class competitive and fun.
The Falken tires are still not allowed which was a big issue with all drivers in the meeting. Also you are now allowed to run off set rims on the Right Rear as well.
Four Fun- Sunset Speedway can now claim any car under the Claim rule.
Also Mild Contact is generally part of racing. In the founr fun class it is not. Deliberate or out of control contact will not be allowed.
I dont think i missed anything.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=5682.msg21962#msg21962
"The Rain Man" Brendan Doherty
Offline Pinecrest
« Reply #2 on: December 05, 2006, 06:12:29 PM »
Thanx for the reply .   The rev limiter thing sounds a little strange .
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=5682.msg21966#msg21966
Offline Doherty
« Reply #3 on: December 06, 2006, 10:04:42 AM »
Well if u change computer, or have ur computer modified u can eliminate ur stock rev limiter and rev the living hell out of ur motor and make more power, where as some of the car stock would hit the rev limiter around the half way down the straights and stop making power. So this will level the feild I think and will stop guys from playing around with the computers.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=5682.msg21971#msg21971
Offline Pinecrest
« Reply #4 on: December 06, 2006, 05:51:21 PM »
Doherty I am aware of the many things you can do with the computer to get more revs but dont you think they would be better off finding someone that knows who to read cam lift and duration on a Honda ?
 If they are serious about this stuff how about pulling a few of the Hondas a part for one thing and is the tech staff at Sunset the only ones on the planet that dont relize that all the fast Mustangs are running Chev rods ?
  If they really wanted a level playing field they would have made all the Hondas weigh 2500 lbs minimum thats the lightest you can get a Mustang to weigh.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=5682.msg21973#msg21973
Offline Matt11
Re: Sunset 4 cylinder rules ?
« Reply #5 on: April 05, 2007, 08:59:20 PM »
You do it right you can get a mustang down to 2300lbs
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=5682.msg24050#msg24050
