Author Topic: metric car diff..  (Read 2050 times)
larue
metric car diff..
« on: September 14, 2009, 06:15:40 PM »
How wide is the stock 7.5 metric car differential??Want to install a 8.5 into this car,and it measures 61 7/16 axle flange to axle flange. ::) ::)
Linkback: /smf/index.php?topic=10549.msg73723#msg73723
metric car diff..
Offline smokinjoe00
Re: metric car diff..
« Reply #1 on: September 14, 2009, 07:05:49 PM »
u sure that is a 8.5 or a floater???   :o
Linkback: /smf/index.php?topic=10549.msg73727#msg73727
larue
« Reply #2 on: September 14, 2009, 08:25:21 PM »
Will a"A" body 8.5 fit into a metric car??
Linkback: /smf/index.php?topic=10549.msg73729#msg73729
Offline sss86
« Reply #3 on: September 14, 2009, 10:26:47 PM »
yes it will fit ,the lower control arms line right up but the uppers are wrong.If you shorten the uppers a lot they will work as well but most tracks wont let you alter the arms that much. its about 4 inchs wider but wheel offset should be able to correct that.
Linkback: /smf/index.php?topic=10549.msg73742#msg73742
« Reply #4 on: September 15, 2009, 12:51:56 PM »
'68 cutlass was supposed to be close
Linkback: /smf/index.php?topic=10549.msg73788#msg73788
