Author Topic: General Race Setup Question  (Read 4302 times)
« on: May 25, 2010, 10:06:04 PM »
OK
I noticed a couple of cars at sunset on Saturday that could get into the turns well and make up a lot of ground on cars but getting out of the turn into the straight away they lost what they gained what causes this?
Linkback: /smf/index.php?topic=11380.msg81892#msg81892
Offline Racing Habits
Re: General Race Setup Question
« Reply #1 on: May 25, 2010, 10:20:07 PM »
OK
Rear end Gears can be set fast into the corner a deeper run or fast out of the corner shorter burst. A choice depending also on other parts of the set up as well as braking ability and grooves. For some guys what they are comfortable with.
Linkback: /smf/index.php?topic=11380.msg81894#msg81894
« Reply #2 on: May 25, 2010, 10:26:32 PM »
Thanks for the quick reply. I guess some drivers are still trying to figure out the new track as setups from last year will not work as well this year.
Linkback: /smf/index.php?topic=11380.msg81896#msg81896
« Reply #3 on: May 25, 2010, 10:44:48 PM »
Perhaps I should have also added that breaking a corner down generally speaking if you have a good entrance it is the basis of a good exit if your entrance is bad you are set up for a bad exit. This is where you hear the terms push and loose used a lot.
Linkback: /smf/index.php?topic=11380.msg81903#msg81903
Offline Wernham
« Reply #4 on: May 25, 2010, 11:08:40 PM »
What is most likely happening is the driver is overdriving into the corner and missing the apex causing him to have to wait on the car to turn before getting back on the gas for corner exit.
Linkback: /smf/index.php?topic=11380.msg81905#msg81905
Offline daisygirl818
  • Out Picking WILDFLOWERS!
« Reply #5 on: May 25, 2010, 11:17:42 PM »
If you want a visual of who enters and exits well Brandon Watson would be perfect. If you look at the Oscaar or lm races this weekend youll see what I mean he follows the curve in and out imo
Linkback: /smf/index.php?topic=11380.msg81906#msg81906
Support the Dream and the WINNERS will follow.
You can bring a RACER to the track but Can't make him RACE!
« Reply #6 on: May 25, 2010, 11:35:28 PM »
The apex is not always available in a race besides a lot of times the driver who is inexperienced does not necessarily relate back to the crew the  right messages about what is going on in the corner. You can bet your top runners know. Wernham you are right about the overdrive, experience shows the fast guys are pretty smooth almost anywhere in the corners
until tires come into play.
Linkback: /smf/index.php?topic=11380.msg81907#msg81907
Offline jibbyjebidiah
« Reply #7 on: May 26, 2010, 12:52:08 PM »
My car is a good example of what Evan is talking about.  Mine is 100% a gearing issue, that will be fixed for this weekend.  My motor is just getting into it's power range at the end of the straightaway and rolls through the corner very well, but is a dog comming out due to the gear ratio that is in the car currently.
Linkback: /smf/index.php?topic=11380.msg81924#msg81924
« Reply #8 on: May 26, 2010, 02:05:11 PM »
jibbyjebidiah what is your car number and what class do you race in?
Linkback: /smf/index.php?topic=11380.msg81927#msg81927
« Reply #9 on: May 26, 2010, 03:25:04 PM »
52 ministock
Linkback: /smf/index.php?topic=11380.msg81930#msg81930
Offline danno428cj
« Reply #10 on: May 26, 2010, 03:41:07 PM »
Best quick fix of this problem is to back up your corner. By that I mean let off a little earlier. You will gain a little less going in, but you wont push through centre giving you a better exit off, thus not loosing as much down the straight. And this will also cool you tires down a little, saving them for when you need to throw it in hard. I will go through my in car videos, and see if i have examples.
Linkback: /smf/index.php?topic=11380.msg81931#msg81931
« Reply #11 on: May 26, 2010, 03:49:42 PM »
that is true dan, but ill have different gears for this weekend and everything should be much better!
Linkback: /smf/index.php?topic=11380.msg81932#msg81932
Offline danno428cj
« Reply #12 on: May 27, 2010, 08:26:01 AM »
Sweet! Can't wait. I'm gonna try to loossen up the car this weekend, too bad practice was cancelled this week.
Linkback: /smf/index.php?topic=11380.msg81950#msg81950
Offline Scott
    • the dizzy pub
« Reply #13 on: May 27, 2010, 04:12:05 PM »
It was the same issue with us, gear gear gear. The car turned better in the feature but I WAS WAY OFF on the gear selection. Nothing worse than getting a run on a car in the corner and the car is a dog coming out. We will have that fixed for Saturday and hopefully not get lapped again,lol.
Linkback: /smf/index.php?topic=11380.msg81962#msg81962
Call Me Crazy But I love The3Tards
Offline zero
« Reply #14 on: May 27, 2010, 04:25:37 PM »
Take it from and old man boys, there is no better friend to a race car on a banked track than stager, and lots of it. 4 inches at least on the back. Give it a try you will be amazed. Trust me boys, Trust me.
Linkback: /smf/index.php?topic=11380.msg81963#msg81963
