Author Topic: Anyone have any tech/general engine questions?  (Read 3136 times)
Offline Rob Hosking
« on: July 11, 2011, 09:21:03 PM »
The heat is getting to me and no housework will get done til it backs down, I'm bored and at the computer quite a bit, so fire away if you care to......
Linkback: /smf/index.php?topic=13704.msg94857#msg94857
Wesley_Motorsports
Re: Anyone have any tech/general engine questions?
« Reply #1 on: July 12, 2011, 08:30:59 AM »
How do you cheat up a Crate Motor and get away with it? :D
Linkback: /smf/index.php?topic=13704.msg94870#msg94870
Offline 2fst4u
    • www.xtremeautomachine.com
« Reply #2 on: July 12, 2011, 09:57:18 AM »
ask Tom walters! bahahaha
Linkback: /smf/index.php?topic=13704.msg94873#msg94873
Offline alan evans
« Reply #3 on: July 12, 2011, 10:38:48 AM »
Don't be one all of your life,take a day off.
Linkback: /smf/index.php?topic=13704.msg94878#msg94878
Offline 2fst4u
« Reply #4 on: July 12, 2011, 10:45:00 AM »
lol it was a joke alan!
Linkback: /smf/index.php?topic=13704.msg94879#msg94879
Offline russell
« Reply #5 on: July 12, 2011, 11:23:30 AM »
I dare you to ask him yourself bonehead
Linkback: /smf/index.php?topic=13704.msg94881#msg94881
Offline don91
« Reply #6 on: July 12, 2011, 11:56:23 AM »
not a question about tech, but one to help drivers save money. if you are running open late model, why spend the extra money on motors they run when you can buy a 602 for around 3400. and put a 4 barrel on it and be just as fast. just wondering, any one else thinking this way?
Linkback: /smf/index.php?topic=13704.msg94882#msg94882
Offline justracin
  • Track Owner
« Reply #7 on: July 12, 2011, 12:27:15 PM »
just  a thought..........Its not the horsepower you have it the horsepower that you use
Linkback: /smf/index.php?topic=13704.msg94885#msg94885
Offline Rob Hosking
« Reply #8 on: July 12, 2011, 12:37:31 PM »
Don,
Asking an engine builder about crates is a loaded question!
Ok, let's say you run an open(pro, ACT) late model. If you start from scratch, your into probably 25k at the minimum to get a name brand chassis, wide 5s, quick change etc with a template body. So your probably not going to worry about the "cost" of a built engine.
I belive the opens run a 604 as well, they are more expensive than the 602 by almost 2 grand.
If you count in the 1000 dollar headers, triple disc clutch and reverse mount bellhousing, trick 2 speed transmissions you easily have 40 grand wrapped up in a car.
Cost is not the issue here per se, crates are low maintenence, easy to hook up if you don't know chassis, and they are pretty much bullet proof.
BUT (there's always a but) the idea behind crates is to make racing more "affordable" which they do, but they also make racing pretty boring. All the wrecks we see nowadays are a product of crates.
If you have car A that is 4 10ths slower than car B because car A doesn't handle, and they both have the same power, car B will have a difficult time getting around if car A drives a narrow line and blocks. So what happens then? Shove him outta the way, that's what happens.
And me, with my legal built engines, has to see a Vortec headed (illegal in all classes) and a 480 lift cam (illegal in tc/ss) run SLOWER than my 1973 heads that have 2 grand into them, AND a stock lift cam! You want to make it "fair" and "affordable"?
Let us run vortecs. They are 99% race ready out of the box (or wrecking yard)
Old open chamber heads need tons of work and $ to make them competitive.
The crates are built to about 70% of what they should be, the weak valve springs and cam profile are limit the hp and rpm range to make them live.
If i could build a vortec headed engine, without the radical  stock lift profile capped at 6200 rpm, i could knock 2 grand i bet off the price of an engine.
You dont need steel cranks, balancing, aftermarket rods, screw in studs, guideplates, you could use 2 piece valves, inexpensive valvesprings, hypereutectic pistons etc etc.
PLEASE refrain from opening up the crate debate again here, start a new topic for that.
If there are tech questions, also open another topic
Thanks
Linkback: /smf/index.php?topic=13704.msg94887#msg94887
« Last Edit: July 12, 2011, 12:55:07 PM by Rob Hosking »
Offline Racing Habits
« Reply #9 on: July 12, 2011, 03:18:28 PM »
Your Point  .....on A & B drivers only stands to reason every track and division has them. Unfortunately the tracks do not have enough cars to put them in a B feature where they belong and learn to be an A. They should always start at the back out of the way of the race volentarily.
Linkback: /smf/index.php?topic=13704.msg94888#msg94888
Offline Rob Hosking
« Reply #10 on: July 15, 2011, 12:26:13 PM »
My point.... Was missed
I mean, ANY 2 drivers with equal horsepower will have trouble passing one another.
I didn't mean A class or B class drivers.
Linkback: /smf/index.php?topic=13704.msg94985#msg94985
Offline flybyya8
  • Track Owner
« Reply #11 on: July 15, 2011, 10:17:46 PM »
 The cost of racing is only as good as the rule inforcement. If you catch the guy with the 6 inch motor/scat crank/383 stroker it sends a message. BUT if the guy promoting the the track south/north whatever lets it go it hurts racing as a whole. They should allow vortec heads, but police them. 5.7 eagle rods, check them, The 602 is easy, MAKE THEM TAKE IT OUT! TAKE A NEW ONE OUT OF THE BOX,IF THEY RUN AWAY STILL TECH THE CARB,ect ect. Dont make a rule if you dont enforce it. I like the rpm rule Rob, less wear and tear.
Linkback: /smf/index.php?topic=13704.msg94996#msg94996
