Author Topic: Mini Stock Gear Setup for Sunset Speedway  (Read 24977 times)
Offline Steviebird31
    • York National Realty Inc. Brokerage
« on: December 19, 2013, 11:29:58 AM »
Hello Everyone,
I am a new driver this year aka (Rookie) coming to race a Sunset Speedway.
I have purchased a 93 Mustang, was raced last year at Barrie Raceway.
Rani Sequin Car # 3 Red Mustang.
Looking for some setup help before opening practise days.
Whats the right gear ratio for sunset?
The car presently has 345 rear end , standard Tran. What Gear should I have?
I was told you run the races in in second gear?
What should my max rpms be at the end of the front and back straights?
Also what tire Psi should I start with as a baseline.
Can't wait to get on track!!!
Linkback: /smf/index.php?topic=18799.msg110119#msg110119
« Last Edit: December 19, 2013, 11:44:16 AM by Steviebird31 »
You can only score on the shots you take!
Offline jibbyjebidiah
Re: Mini Stock Gear Setup for Sunset Speedway
« Reply #1 on: December 20, 2013, 02:22:09 AM »
Your rear gear depends on what transmission you have. Is it a 4speed or a 5speed manual?
Linkback: /smf/index.php?topic=18799.msg110120#msg110120
« Reply #2 on: December 20, 2013, 10:57:52 AM »
Sorry 4 Speed Manual Trans
Linkback: /smf/index.php?topic=18799.msg110123#msg110123
« Last Edit: December 24, 2013, 09:53:24 PM by Steviebird31 »
« Reply #3 on: December 26, 2013, 09:27:46 AM »
I ran a set of 3.27 and it put me in the 7200+ RPM range in second gear.  A set of 3.08 would be more ideal.
Linkback: /smf/index.php?topic=18799.msg110137#msg110137
