Author Topic: Thurs Sept 18th Canadian LLM Championship  (Read 1877 times)
Offline MarkDilley
« on: September 02, 2014, 09:53:33 PM »
Change to Sunset Schedule Thursday Sept 18th will now be a 125 lap LLM race paying $2600 to win and $300 to start also we will run a 35 lap Mini Stock paying $400 to win will have all details and rules tomorrow.
Mark
Linkback: /smf/index.php?topic=20167.msg112216#msg112216
Offline MarkDilley
Re: Thurs Sept 18th Canadian LLM Championship
« Reply #1 on: September 03, 2014, 09:07:14 AM »
CANADIAN LIMITED LATE MODEL CHAMPIONSHIP
DATE: Thursday September 18 2014
TIMES:
 PIT OPEN 12PM, GRANDSTAND 430 PM, RACING 6PM
LIMITED RULES.
602 or built Limited motors only NO 603 or 604
Ride height 5 driver out
75lb weight break after 125 lapper
No Coil Over
No Multi Piston Calibers
All other rules same as your registered home track 2014 rule book states have copy.
Tire Rule
Hoosier 980 all tires will be marked on pit road before qualifying these will be the tires all cars start the 125 lapper on.
Cars in last chance races may use other tires but must start the race with their marked time trial tires.
Four tires must be purchased from the race at track tire shed will open at 12 am on race day, tires will be available days before event but will be mounted at speedway and impounded in tech shed till race day no tires will leave the property before event.
Only tire that will be allowed to be changed is the one optional tire at race break any other tires that are changed during 125 lapper must be flat if tire is deemed not to be flat it will be a 1 lap penalty per tire changed.
Race Format
125 laps
12 Cars thru time trials ($100 pole)
Inversion for start 2 dice roll by pole sitter
Final 12 spots will qualify thru last chance races (all pending amount of cars making an attempt to qualify.
Competition Yellow will be thrown at lap 75 or within 5 laps if yellow is already out at this time cars will come down pit road with the option of making chassis adjustments.
Teams will have the option of taking on ONE tire if this option is taking advantage of than car will go to rear of field.
 Example you are running 1st at break you decide to take a tire but 7 cars dont then you would start 8th being the first car that used the tire option.
1.   $2600.00
2.   $1500.00
3.   $1200.00
4.   $1000.00
5.   $850.00
6.   $750.00
7.   $650.00
8.   $600.00
9.   $550.00
10.   $500.00
11.   $450.00
12.   $450.00
13.   $450.00
14.   $400.00
15.   $400.00
16.   $350.00
17.   $350.00
18.   $350.00
19.   $300.00
20.   $300.00
21.   $300.00
22.   $300.00
23.   $300.00
24.   $300.00
    Sept 18 Mini Stock Rules
Home Track Rules please have 2014 rule book with you.
Race Format
35 Laps
28 Cars Start
Draw number at PIT GATE when signing in for heat starting position.
Single heat format
Winner of first heat will roll double dice for starting order of 35 lapper
18 cars qualify thru heats subject to change pending car count
Remainder of field Qualify thru last chance races
1   400
2   300
3   230
4   180
5   150
6   120
7   100
8   90
9   90
10   90
11   90
12   80
13   80
14   80
15   80
16   80
17   70
18   70
19   70
20   70
21   60
22   60
23   60
24   60
25   60
26   60
27   60
28   60
Linkback: /smf/index.php?topic=20167.msg112217#msg112217
Offline Derek
    • http://www.racepulse.com
« Reply #2 on: September 19, 2014, 11:51:53 AM »
Unofficially, the 125 lap Limited Late Model Invitational was won by Taylor Holdaway. Mike Bentley was 2nd, Brandon Watson 3rd, Tom Walters 4th and Sean Cronan 5th. Andy Kamrath won the Mini Stock Invitational, followed by Ryan Babin, Bill Schwartzenburg, Tyler Junkin and Jordan Howse.
I'll post photos here and on www.racepulse.com as soon as i can.
Linkback: /smf/index.php?topic=20167.msg112347#msg112347
