Author Topic: Engine Question  (Read 4682 times)
Re: Engine Question
« Reply #15 on: February 26, 2009, 08:34:23 AM »
do most garages have this or would you have to call around to find one that does?
it appears thaynes dad does, but ask around and dont let them sell you the quicky verision do thru the pcv valve.
Linkback: /smf/index.php?topic=9365.msg65211#msg65211
Re: Engine Question
Offline napa55
Re: Engine Question
« Reply #16 on: February 26, 2009, 07:01:14 PM »
cut the filter open to see if any damage is occuring
Quick and easy trick with the oil filter, attach a small magnet to the filter with a gear clamp, then when you cut open the filter all the iron particles will be stuck to the side of the filter where the magnet is.  I have used the magnets that are bonded to the inside of G.M. diff covers, works great!!
Linkback: /smf/index.php?topic=9365.msg65231#msg65231
Re: Engine Question
« Reply #17 on: February 27, 2009, 10:43:04 AM »
yeah i even put themunder the valve covers.
Linkback: /smf/index.php?topic=9365.msg65241#msg65241
Re: Engine Question
Offline boas51
Re: Engine Question
« Reply #18 on: April 11, 2009, 11:22:28 AM »
Routine Maintenance Sheet
Car ______________________
_______________ Ride heights                #   date
_______________ Scale                  ___   _________
_______________ Toe out
_______________ Wash car - wash out radiator      ___   _________
_______________ Battery charged
_______________ Engine oil/filter            ___   _________
_______________ Coolant
_______________ Power steering fluid            ___   _________
_______________ Transmission oil
_______________ Differential oil               ___   _________
_______________ Grease all suspension, u-joints
_______________ Wheel bearings            ___   _________
_______________ Brake fluid
_______________ Brake rotors, calipers and pads      ___   _________
_______________ Air cleaner/carburetor fittings/bolts
_______________ Fuel filter               ___   _________
_______________ Valve lash
_______________ Ignition timing/distributor clamp      ___   _________
_______________ Tighten header bolts
_______________ Belts and hoses            ___   _________
_______________ Control arms and bolts
_______________ Trailing arm and track bar bolts      ___   _________
_______________ Motor, transmission and starter bolts
_______________ Shifter linkage/ Clutch linkage      ___   _________
_______________ Drive shaft bolts
_______________ Shock mounts
_______________ Steering components
_______________ Body mounts
_______________ Wheels and tire wear
_______________ Bumper bolts
Notes: __________________________________________________________
________________________________________________________________
________________________________________________________________________________________________________________________________
this is my routine maintenance, no repair or setup. allthough some does overlap.
Linkback: /smf/index.php?topic=9365.msg66420#msg66420
