Author Topic: 350 Turbo/powerglide  (Read 5693 times)
larue
« on: March 03, 2009, 12:12:42 PM »
Do you guys think the powerglide is worth the 50lb weight penalty??
Linkback: /smf/index.php?topic=9403.msg65443#msg65443
Re: 350 Turbo/powerglide
« Reply #1 on: March 03, 2009, 01:48:55 PM »
yes especially if one can get an aircooled one with the smaller converter
Linkback: /smf/index.php?topic=9403.msg65448#msg65448
Offline Thunder6
  • Don't mess with Tex
« Reply #2 on: March 04, 2009, 12:03:31 AM »
No weight penalty at Barrie  ;D
Linkback: /smf/index.php?topic=9403.msg65460#msg65460
"Dont be BEECH! And as always comrades, have nice day" fpsrussia
larue
« Reply #3 on: March 05, 2009, 10:37:10 PM »
Are they ones,out of Vega's??
Linkback: /smf/index.php?topic=9403.msg65486#msg65486
« Reply #4 on: March 06, 2009, 08:32:47 AM »
i beleive so and also chev II i think
Linkback: /smf/index.php?topic=9403.msg65492#msg65492
larue
« Reply #5 on: March 09, 2009, 10:10:10 PM »
T.c.i. make great trans,just very expensive!!
Linkback: /smf/index.php?topic=9403.msg65559#msg65559
Offline Team 33
« Reply #6 on: May 31, 2009, 09:07:43 AM »
I have two for sale a TCI & Coleman ......519-615-2674
Linkback: /smf/index.php?topic=9403.msg67849#msg67849
larue
« Reply #7 on: August 24, 2009, 09:49:14 PM »
What seems to be the weak link with the slip slide powerglide?Seems like alot of guys who run this 40 year old trans,have failures....Are you running them in 1st,or 2nd?
Linkback: /smf/index.php?topic=9403.msg72301#msg72301
« Reply #8 on: August 25, 2009, 04:58:10 PM »
Are these transmissions what we used to call a "Mexican Two Speed"? I know a lot of guys swore by them years ago.
Linkback: /smf/index.php?topic=9403.msg72332#msg72332
Offline Thunder6
« Reply #9 on: September 22, 2009, 02:29:23 AM »
The casting is thin right at the back of the case where all the reverse stuff is. We had one that was fine in park and all the forward gears but if you put in reverse it would puke its guts out.
Linkback: /smf/index.php?topic=9403.msg74250#msg74250
Offline Thunder6
« Reply #10 on: September 22, 2009, 01:52:48 PM »
I think Larry's question was about the weakest area of the transmission. I tried to answer that to the best of my ability, from my experience with those units. We have had a few failures...
I don't think anyone should put a 40 year old transmission in a race car without having a look to see what's in there, but that's just me... Maybe some people might...
Linkback: /smf/index.php?topic=9403.msg74272#msg74272
Offline Racing Habits
« Reply #11 on: January 31, 2010, 04:36:57 PM »
« Reply #12 on: November 07, 2010, 07:27:39 AM »
The powerglide reverse issue comes from the pressure being to high when shifted into reverse. I was told like of the car was stuck and it was shifted into reverse at high RPM. Of all the glides I messed with only one was blown like this. The thing to do is to keep the band adjusted properly if using it in first gear. It's easy to do and doesn,t take long
Linkback: /smf/index.php?topic=9403.msg89549#msg89549
