read rule 11.
if this rule is enforced as written, 150hp cobalt@2850 lbs., sohc neon @ 2565lbs, dohc neon @2750, nissan 240 @2750lbs.
hondas? too many to different options to mention.2-3000 lbs depending...
Mustang 2000 lbs min.
vw 2000 lbs min
cavalier 2000lb -2800 depending on year/motor
find out what the "real" rules are before you do anything
11. Weight
Minimum weight is 2000 lbs or 19 lbs/ horsepower as manufacturer advertised at the crankshaft (whichever is greater). Maximum left side weight is 55%. Weights will be done with driver in car. Ballast weight must be securely fastened with minimum 3/8" grade 8 bolts, painted white with car number on them and maintain the 5" ride height. Maximum rear weight is 50%.
Sauble Speedway reserves the right to add any amount of weight to any location on any car deemed to be too fast in order to keep this class competitive and fun. The extra weight to be supplied and installed by car owner.
Weight will be added to the first and second place finishing cars each feature event. It must be in place for the following event and for the remainder of the season in the designated location by the tech director. The weight penalty for first place will be 25 lbs and 10 lbs for second. After competing with penalty weight a competitor may lobby for penalty weight removal.
Note: If the make model and year you are racing is less than 100 manufacturer advertised hp you are permitted to modify to achieve 100hp. Any proposed modifications must be submitted in writing and approved by Sauble Speedway.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=12148.msg89023#msg89023
