the rules always seemed easy to understand, and actually make a bit of sense. just seemed if you have rules but don't bother to enforce, what's the point of the rule?
so some examples
sohc neon 135 hp 2565 lb
2.2 dohc sunfires 140 hp 2660 lb
dohc neon, cavalier ecotec,cobalt, Nissan 240, 145 hp 2755
(maybe some newer cobalts. g6 higher?)
1.8 dohc vw 125 hp 2375 lbs
2.0l vw golf 115 hp 2185 lbs
2.2 gm sohc 120 hp 2280 lbs
mustang, vw 1.8, charger/shadow, 2000 lbs
hondas? 60-190 hp depending on what parts you put together
maybe they ought to add a maximmum so you don't have 3000lb mini stocks. but i guess if you bring a 160hp car to the track, maybe it's fair.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=12649.msg90505#msg90505
