May 10th 47= heat 1 20, heat 2 24, feature 64, total 108
11= heat 1 24, heat 2 18, feature 56, total 98
May 17th 47= heat 1 20, heat 2 24, feature 50, total 94 overall 202
11= heat 1 22, heat 2 24,feature 56, total 102 overall 200
May 24th 47= heat 1 24, heat 2 24, feature 64, total 112 overall 314
11= heat 1 24, heat 2 20, feature 52, total 96 overall 296
May 31st 47= heat 1 24, heat 2 22, feature 60, total 106 overall 420
11= heat 1 18, heat 2 24, feature 52, total 94 overall 390
June 7th 47= heat 1 24, heat 2 24, feature 53, total 101 overall 521
11= heat 1 24, heat 2 17, feature 64, total 105 overall 495
June 21st 47= heat 1 24, heat 2 24, feature 64, total 112 overall 633
11= heat 1 22, heat 2 24, feature 47, total 93 overall 588
June 28th 47= heat 1 22, heat 2 24, feature 60, total 106 overall 739
11= heat 1 24, heat 2 12, feature 64, total 100 overall 688
July 19th 47= heat 1 24, heat 2 22, feature 64, total 110 overall 849
11= heat 1 22, heat 2 17, feature 56, total 95 overall 783
August 16th 47= heat 1 20, heat 2 24, feature 60, total 104 overall 953
11= heat 1 24, heat 2 18, feature 64, total 106 overall 889
August 23rd 47= heat 1 24, heat 2 24, feature 64, total 112 overall 1065
11=heat 1 20, heat 2 24, feature 60, total 104 overall 993
August 30th 47= heat 1 24, heat 2 20, feature 64, total 108 overall 1173
11=heat 1 22, heat 2 22, feature 56, total 100 overall 1093
Sept 6th 47= heat 1 20, heat 2 24, feature 54, total 98 overall 1271
11= heat 1 22, heat 2 22, feature 64, total 108 overall 1201
Last night of racing double features.
Sept 13th 47= heat 1 17, heat 2 24, feature 0, total 41 overall 1312
11=heat 1 20, heat 2 20, feature 64, total 104 overall 1305
Sept 20th 47= heat 1 24, heat 2 20, feature 54, total 98 overall 1410
11=heat 1 15, heat 2 24, feature 64, total 103 overall 1408
Silversone You are quite accurate in you findings for june 28th.Sunset would have scored morrow at 699 when it should have been 688.The extra point differance came from sept.20th heat #1 when walters had the #11 of morrow finishing 7th and the #6 finishing 6th when in fact morrow finished 6th and the #6 finished 7th.The actual points total that walters should have posted for morrow should have been 1409 as he had a 1 position error which equated to 1 point in that heat.The final points total that i received from another scoretakers source should have read walters 1410 morrow 1409.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8758.msg58050#msg58050
