Author Topic: tire rule  (Read 2709 times)
Offline disturber
tire rule
« on: May 07, 2014, 09:31:23 AM »
was reading the Barrie mini stock tire rule, says basically all tires have to be the same (195-60-14 or 205-50-15 azenis no mixing). just wondering how guys are getting stagger if they need it. is it just using a new and worn out tire or...
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=19109.msg110889#msg110889
tire rule
Offline jprosevear
Re: tire rule
« Reply #1 on: May 07, 2014, 02:02:47 PM »
I've moved the worn tires back.  I've also seen up to 3/8" difference in circumference from the factory to get some play.
-JP
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=19109.msg110890#msg110890
Offline disturber
Re: tire rule
« Reply #2 on: May 08, 2014, 09:40:42 AM »
i know that cars with welded diffs often want more than an inch or circumference stagger and that's tricky to get with just worn/new tire. i remember talking to a fast nissan guy last year and he mentioned his car was happy at 2-2.5 and i peeked at a fast mustang at sunset and saw 185 lr and 195rr so im guessing that is a couple.
looks like a tough rule to work with (but maybe setting up with no stagger is easier than i thought and can work good)
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=19109.msg110896#msg110896
Re: tire rule
Offline polishprince12
  • 2010-2011 Track Champion
Re: tire rule
« Reply #3 on: May 12, 2014, 05:31:21 PM »
shave them to get stagger! I can help with that!
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=19109.msg110931#msg110931
Offline cookin240
Re: tire rule
« Reply #4 on: May 13, 2014, 10:04:03 AM »
use a LSD no need for stagger.. if your car is well balanced and not a mustang an open diff works just fine too.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=19109.msg110942#msg110942
