Just posted on the Full Throttle Facebook page
“Full Throttle Motor Speedway "Street Stock" competitors- the 2014 schedule will include 5 races for the SS class, August 22nd, September 12, October 3, October ...10 and October 17. All will be twin 20's format with the V8TS purse.
Rules- Stock appearing steel body(fiberglass hood add 20lbs),stock firewall (add 40lbs without), automatic transmission, stock exhaust manifolds, stock rear suspension, load bolts rear only(add 20lbs with), Holley 4412 2BBL carb or stock carb, hydraulic cam- 410/390 lift rule applies (GM 602 crates add 75lbs), Hoosier 790 tire/ street legal DOT tire/ 7" rims only, 3250 pound base weight (after race with driver). Register online ASAP to be added into the computer system.”
If you have any questions just go over to the Full Throttle Facebook page!
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=20069.msg112096#msg112096
