WestWorld Motorsports is cleaning out the shop to make room for some new equipment. All cars and parts are located in Edmonton. For more information please contact Jeff at 780-419-7233 or Daryl at 780-983-0937 or see
http://www.darylharr.com/darylharr.com/RaceCars_and_Equipment_for_Sale/RaceCars_and_Equipment_for_Sale.html For Sale
2010 Chevrolet Impala SS NCATS Road course car 71-03 $25,000
Last raced Aug 2009 in Montreal Grand Prix finished in the top 10. Built in 2002 by McColl Racing with best of everything. Car is set-up and race ready minus drivetrain. Was updated to NASCAR spec in 2009 with new rear clip, ignition, wiring, SFI roll bar padding and DuPont FE36 Fire bottle. Built as purpose built R/C car with RS oil tank with lightweight Kevlar lines, watts link or panhard bar setup, rear sway bar, brake fluid recirculators, full LS and RS lead rails, rear end cooler, equal length control arms and spindles, windshield wiper, defroster. The car is also equipped with 4 - 5” brake fans for optimal cooling and a 10:1 steering box and setup for a NASCAR spec engine with underslung headers and exhaust. Included is all car set-up history and notes. Could be converted to oval car.
Can be sold completely race ready with engine, transmission, gear and setup.
2003 Chevrolet Monte Carlo CASCAR oval track spec 71-05 $12,000
Championship winning car in CASCAR West with Daryl Harr. Built by McColl Racing in 2002 with best of everything and optimized roll center by WestWorld Motorsports. Car comes as-is near complete straight off the track minus drivetrain and seat. Features of this car include 3 piece splined cup style sway bar, various titanium drilled bolts, drill axles, dual MSD ignition, rear end cooler, VDO gauges w/ replay tach, Halon fire bottle, collapsible steering column, sweet 12:1 steering box, cools-it radiator with oil cooler, dry sump tank with lightwight Kevlar lines, underslung headers with CASCAR mufflers / exhaust. Very light with many race wins and track records. Sister car and built identical Westworld car 2-04 also for sale.
2003 Chevrolet Monte Carlo CASCAR oval track spec 2-04 $12,000.
Built by McColl Racing in 2002 with best of everything and optimized roll center by WestWorld Motorsports. Car comes as-is near complete straight off the track minus drivetrain and seat. Features of this car include 3 piece splined cup style sway bar, various titanium drilled bolts, drill axles, dual MSD ignition, rear end cooler, VDO gauges w/ replay tach, Halon fire bottle, collapsible steering column, sweet 12:1 steering box, cools-it radiator with oil cooler, dry sump tank with lightwight Kevlar lines, underslung headers with CASCAR mufflers / exhaust. Very light with many race wins and track records. Sister car to 71-05 which is also for sale.
Optional Spares to go with Cars
Spares Bin #1 R/C front suspension
Spare pitman arm
2 – spare LS R/C lower control arms
spare LS R/C spindle
spare RS R/C spindle
spare front hub with bearings and rotor
spare complete RS tie rod set
spare complete LS tie rod set
spare Idler arm
Spare Bin #2 Oval front suspension
3 – spare LS oval lower control arms
Spare LS oval spindle
Spare Rs oval spindle
Spare idler arm
Spare bin #3 Rear Suspension Parts
2 – spare rear hubs with rotors
5 - various length trailing arm, 3rd tubes
spare rubber trailing arm bushing
spare 3rd link housing and rubbers
spare round style panhard bar brackets (frame side)
spare rotating panhard bar bracket (rear end side)
Others
Box of Misc front and rear bearings for hubs
NCATS / CASCAR oval Rear end housing - used unknown condition
2005 Monte Carlo SS 105 wheelbase NASCAR K&N Pro Series Car. $10000
2001 Dave Davis NE Chassis with DEI body. Green house is ok but needs nose tail and sides. 1 ½ drop clip with Fully slugged front upper and lower suspension adjustment, brembo brakes, Tiger Quick change polished lightweight rear end,12:1 sweet steering box and comes with both open and muffled exhaust systems for NASCAR spec engine. Car is complete minus seat, engine, transmission, fuel cell and ignition.
Hendrick chassis #167 with no body for ARCA, NASCAR K&N Series $8000
Car is currently stripped but all parts are included including cambered rear end housing and brembo brakes, lightweight lines. Does not include engine, transmission, gear, seat
Parts and Equipment
CASCAR Rims 15 x 8 $50 each or $1000 for all
25 rims in all good condition. 3 ½ offset some 1 race
6 sticker CASCAR good year tires $200 for all
D2651, D2651, D2691, D1791, D2491, D2491 compounds
Richmond T-10 $2000
Fine Spline, Rebuilt Tranny, Rebuilt by LP Gear (North Carolina) Fresh, Ratios: 1:23, 1:43, 1:61, Fine spline.
Box of Misc. Bearing and Seals $40
37 pieces total 6- misc. u joints, 8 - bearing NTN #4T-2793, 1- Federal Mogel Release bearing #614009, 3- National Seals #471737), 1 - National Seals # 415281N, 1- CR Seals #19277, 1- CR Seals #18264, 1- CR Seals #18658, 4 - National Seals #8139, 4- National Seals #476023N, 7- National Seals#3604
New Chevy 6 Bolt Pressure Plate $100 for all
3 available to choose from, 1- 16lbs, 2 – 13lbs.
Used Chevy 6 Bolt Pressure Plate $10 each or $50 for all
7 all decent condition weights varying from 11 to 16 lbs $10 each
Holley 4150 VDL 390 CFM carb $300
Serieal #757402 Flows 536 cfm built by Keith Dorton 2002 with fuel log
Holley 4150 VDL 390 cfm carb $300
Serial #57502 AS#5 flows 536 cfm built by Keith Dorton in 2002
Serial #52407 flows 547 CFM built June 2000 by Keith Dorton
Holley 4150 390 carb- 80507 $300
Off CASCAR C64 serial 80507-0937
Off CASCAR C63 serial 80507-0937 no boosters, no secondary accerelator pump
Holley 4150 390 carb – 80507 $300
Off CASCAR C138-00 serial 805067-2-0410 no secondary linkage
Holey 4150 830 carb $300
Off NASCAR cup engines part #4150-80785-1230 AS#2 built by Dorton
Off NASCAR cup engines part #4150-80785-1730 AS#1 built by Dorton
Off NASCAR cup engines part #4150-80785-1750 AS#3 built by Dorton
Quarter Master Chevy starter $50
GM high torque starter $50
SBC Cylinder Head #3982441 $20
Used SBC cylinder heads #3982441 look stock 76cc 1.94 intake 1.50 exhaust need rebuilt
SBC Cylinder Head #3986336 $20
COMP CAM #12-515-5 Dyno $20
Dyno time only and comes with set of lifters for SBC. I .55” @ 0.05 E 0.57" @ 0.05 106 degree lobe seperation
Crane Cam #11F000607 Dy no $20
Dyno time only and comes with a set of lifters for SBC I .3667 E .360
Crane Cam #11F000479 Dyno $20
Dyno time only and comes with lifters for SBC intake 382 exhaust 394
Crane Cam #11TLF0023 Dyno $20 Dyno time only and comes with lifters for SBC intake .3600 exhaust .3734
Keith Dorton Custom Grind Cam $20
each cam comes with lifters and dyno time only. Custom ground to specs from Keith Dorton at Automotive Specialists in N.C 3 to to choose from. $20 each
Crane Cam 11F000607 2000 laps $10
Crane Cam #11F000607 comes with lifters only for SBC intake .3667 exhaust .360 approx 2000 laps
Isky # 8305 Valve Spring set $10
Set of used valve spring SBC 1.510" OD open pressure 380 lbs@ 1.275" seat pressure 160lbs@1.875"
Comp. Valve Springs #950-16 $10
Set of used Valve Spring set SBC 1.464" OP open pressure 332 lbs@ 1.3" seat pressures 133lbs@1.9"
Comp. Valve Springs #991-16 $10
Set of used valve spring set SBC 1.639 OD open pressure 662@ 1.25" seat pressure 214lbs@ 1.95
Manley Pistons $80
Bore 4.060 Compression Height 1.55 Used from CASCAR engine.
Wiseco Pistons $80
J.E. Pistons
Bore 4.120 Comp. Ht. 1.33 used from 9:1 NASCAR engine
Wiseco Pistons $80
Bore 4.060 Compression height 1.33 used from CASCAR engine
Manley Pistons and Rods $150
Used set out of CASCAR engine. Manley H-beam rods 5.7" length, Manley Pistons 4.057" bore 1.550 compression height.
Dry Sump Oil Tank $50
Trianluar tank approx 5 gallon with -16 fittings and oil heater
Spare Tiger Quick change rear end $1200
Used in NASCAR K&N Pro Series. 4.11 aluminum carrier, REM polished, aluminum bells, steel tubes with truck arm mounts, panhard bar mount, superspeedway hubs. Zero laps since refreshed by L.P. Gear in North Carolina. Could put in tubes to suit any car.
lightened spur gears for Quick Change $350
7.00 (2), 6.85, 6.68, 6.54, 6.28, 6.16, 5.96, 5.80, 5.72, 5.63, 5.48(2), 5.34, 5.26, 5.04, 4.85, 4.64, 4.52, 4.41, 4.33
Ford 9” Rear end housing 1.5 camber $250
60 +1/2 -1/2 from hendrick cup car with super speedway snouts, truck arm
Ford 9” rear end housing 1.5 camber $250
60” with super speedway snouts, truck arm mounts and sway bar mounts
Ford 9” Closed Storage Containers $10
Closed stype Ford 9” 3rd member storage containers which are stackable.
Ford 9” Open Storage Containers $10
Open style Ford 9” 3rd member storage containers.
SBC underslung headers from cup car $100
2” primary and 3 ½ collector
1 ¾ primary with tri-Y 3 ½ collector
1 7/8 primary with tri-Y 3 ½ collectors
ATL 22 Gallon Fuel Cell Bladder $100
ATL Super Cell 200 fuel cell bladder MFG Date 1 QTR 2000 17" x 33" x 9" deep with pickup and foam, no fill plate or can.
ATL Super Cell 300 fuel cell bladder MFG Date 2 QTR 1998 17" X 33" x9" deep with trap door style pickup and foam, no fill plate or can.
ATL Super Cell 300 fuel Cell bladder MFG Date 1 QTR 2000 17" x 33" x 9" deep with bicknell pickup and foam, no fill plate or can
ATL 22 gallon Fuel cell complete $500
Comes with foam fill plate setup for dump can, and can. 5 years old
Nomex Shifter Boot $20
Nomex shifter boot from Simpson Racing Products. 2 available.
Fire Bottle $50
Halon 1211 5lbs fire bottle
Automatic Release Fire Bottle $50
Halon 1211 automatic heat sensing release 10 lbs fire bottle. Needs nitrogen pressurized
Bolt-On seat leg braces.
$20 each.
6 – point willians seat belts 4 years old $20
6 New Rear 8-Bolt Rotors $100 for all
6 x 8 bolts x 1.25" thick x 11.75" tall non-directional vane rotor only weight 8.9lbs each great for rear rotors
20 Used Rotors Front and Rear $100 for all
20 used rotors decent condition 6 lefts, 5 rights, 6 rear all 8 bolts misc. makes. $100 takes all!
GM Caliper Package $40 for all
6 used GM calipers 4 lightened big GM style (saves 4lbs per set) 1 stock weight Big GM style, 1 stock Metric GM style. $40 takes all!
Brake Blower Fans $10 each, or $100 for all.
Various conditions 13 fans in all
Wilwood Calipers kit $300
Comes with 5x5 brake hats and rotors and left and right Wilwood super lite 1 ¾ and 1 1/2 piston calipers
Springs
25 springs between 725 and 1500lbs. $25 each or $250 for all
Used Cools It Radiator from NCATS $250
28 ½ (31 at cooler) x 19 x 3 with oil cooler RS -16 upper rad hose fitting with fan. -6 line for surge tank. Double pass. -16 on cooler
Used Cools It Radiator from NCATS $200
28 ½ (31 at cooler) x 19 x 3 with oil cooler RS -16 upper rad hose fitting 1 ¾ lower. -6 line surge tank. Double pass. -16 on cooler, -6 for surge tank
Used C & R Cup radiator with oil cooler $200
28 ½ (30 at cooler) x 19 x 4. -20 upper rad hose fitting 1 ¾ lower on RS. Double pass -16 on cooler -6 for surge
Used Cup radiator with cap $150
30 (30.5 at cooler) x 19 x 3 ½ with -16 oil cooler. Unknown brand
Used Cup radiator 28x 181/2 x 4 cooler $150
Complete 2003 Monte Carlo CASCAR body with windows $800
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11013.msg78911#msg78911
