Author Topic: Floater rearend  (Read 1468 times)
Offline polishprince12
  • 2010-2011 Track Champion
Floater rearend
« on: October 12, 2012, 09:43:42 AM »
i have a gm gbody metric chassis with stock lowers and #2 spindles with the big rotors. does anybody know the proper width rearend to put in the car, flange to flange? i want to order the proper rearend, mine is currently 58" and is way too narrow! thanks for the help!
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=16665.msg105594#msg105594
Floater rearend
Offline JimmyThunder
Re: Floater rearend
« Reply #1 on: October 12, 2012, 11:06:47 AM »
when I ran super street I had the rear width an inch narrower than the front . Think it was 63in?
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=16665.msg105595#msg105595
Offline dodgeguy14
Re: Floater rearend
« Reply #2 on: October 12, 2012, 10:31:08 PM »
G body is 59" hub face to hub face on the front stock, lengthened lower on the front puts you at 60". I'd say 58.5 or 59" would be ideal. Don't forget to line up your right side tires with each other. They have to track in line.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=16665.msg105601#msg105601
Re: Floater rearend
