Author Topic: Super Stock question  (Read 23675 times)
« on: October 22, 2009, 07:13:14 PM »
I was told 84-91 Vettes came with aluminum water pumps part number GM #14047008  If so can we use an aluminum vette pump?
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=10748.msg75872#msg75872
« Last Edit: October 22, 2009, 07:23:40 PM by jworacing »
Offline LAKER77
Re: Super Stock question
« Reply #1 on: October 22, 2009, 08:41:21 PM »
Best to check with Jeff at the banquet . Maybe not. Call him after the banquet. Hopefully your team is coming saturday. It was certainly a pleasure having you guys join us this year and look forward to racing with your team for many seasons to come.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=10748.msg75875#msg75875
larue
« Reply #2 on: October 22, 2009, 09:35:43 PM »
Alot of the rules book say no aluminum water pumps,except fords,but your right they were stock gm parts. ;)Try finding a short stock cast one,from old corvette's,they work fine also.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=10748.msg75876#msg75876
« Reply #3 on: October 23, 2009, 09:26:50 AM »
Well were looking at the KRC serpentine kit and it comes with an aluminum vette  pump so I was hoping to use it. And to the 77 team you guys are fricking great to race with and thanks for all the help. BOOOYAAHH
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=10748.msg75893#msg75893
« Last Edit: October 23, 2009, 09:29:43 AM by jworacing »
Offline Dougy109
  • Known by my brothers as 'Bones"
« Reply #4 on: October 23, 2009, 10:58:08 AM »
Not an expert, just tried it, refused to listen to conventional thinking, broke all the parts trying
Offline streetstocker33
« Reply #5 on: October 23, 2009, 12:25:25 PM »
WATER PUMP -- Stock O.E.M. water pumps only. NO anti freeze allowed in the cooling system. No special racing
pumps and must use stock-type v-belt drive.....................................that's straight out of the rule book, so the pump MIGHT be legal (i'd talk to jeff) but the serpentine system isn't.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=10748.msg75899#msg75899
larue
« Reply #6 on: October 23, 2009, 01:48:16 PM »
serpentine belts have been used for the last 25 years,so whats the concern??damm,they use them in pick up trucks..lol
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=10748.msg75901#msg75901
« Reply #7 on: October 23, 2009, 02:00:05 PM »
just an old rule that hasn't been updated...................aren't you a thunder car guy larry? thunder car guys don't need to talk about rules being outdated LOL
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=10748.msg75903#msg75903
Offline smithbarney
« Reply #8 on: October 23, 2009, 03:07:08 PM »
Why do you want to go down this road? (if for the weight run a fiberglass hood, or gut the rad cradle... many have done that with out too much notice... )
Is this class not set up to be an entry level so those who desire can move on?
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=10748.msg75908#msg75908
larue
« Reply #9 on: October 23, 2009, 03:11:11 PM »
who ever said super stock or thunders,are a entry level class??
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=10748.msg75909#msg75909
« Reply #10 on: October 23, 2009, 03:15:46 PM »
I don't think running an aluminum water pump would take a class out of the entry level category.....if you run a fibreglass hood you have to add weight (and depending on the supplier, a lot of $$$), and i don't think any of the cars have rad cradles anymore, it's been a few years since we started taking them out and just making fender mounts off of the hoops.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=10748.msg75913#msg75913
larue
« Reply #11 on: October 23, 2009, 03:22:21 PM »
its called doing your homework,if the rulebook doesnt say, you cant run aluminum water pumps,whats the problem?
Its the guys who dont know enough about researching stuff,that would complain about running a aluminum water pump.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=10748.msg75915#msg75915
larue
« Reply #12 on: October 23, 2009, 03:25:38 PM »
you have ex super late model drivers dropping back into thunder cars,what seems to be the concern?It is not entry level no longer...
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=10748.msg75916#msg75916
« Reply #13 on: October 23, 2009, 03:39:58 PM »
that might be the case in a perfect world, but it's all up to the tech guys.......if it doesn't say you can run it, and they don't think it's a good idea then you'll end up just having to change it, which on something like that (that will make a tiny little difference), i'd just ask before buying. and since serpentine systems aren't legal, they don't have to worry about not being able to use the pump that comes in the kit they wanted to buy.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=10748.msg75918#msg75918
Offline JAMR
« Reply #14 on: October 23, 2009, 03:51:58 PM »
Ask the tech guys in writing and get the answer in writing. No more gray area. MHO :D
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=10748.msg75920#msg75920
Crew, Ohsweken Mini Stock #76
Lead, Folllow, or just get out of my way.
