Author Topic: Cayuga Thunder Car Invitational  (Read 5356 times)
Offline Thunder6
  • Don't mess with Tex
Re: Cayuga Thunder Car Invitational
« Reply #15 on: July 08, 2008, 11:02:38 PM »
rossevans30, our cam lift rules are .390 /.410 which i believe is the same as Sunset. I would estimate our power at 280 Hp with the 4412... Sunset runs the Rochester, no 4412.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=7753.msg46779#msg46779
"Dont be BEECH! And as always comrades, have nice day" fpsrussia
« Reply #16 on: July 09, 2008, 09:48:17 AM »
Flammy does not allow couplers, 602's are not as far off as you think with the builts depending on the guts. You can't urn the 602 much over 6000. if you do you're asking for it.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=7753.msg46799#msg46799
Offline Thunder6
« Reply #17 on: July 09, 2008, 06:33:33 PM »
JWO I would think the 602 is about 330 Hp, GM rates that engine with a 4 bbl at 350 Hp... It's a quality piece and the Vortech heads make big power... Cylinder head technology has come light years since the 1970's. Most crates won't spin over 6000 or so, they weren't intended to do that. JMO of course...
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=7753.msg46841#msg46841
Offline LAKER77
« Reply #18 on: July 10, 2008, 10:37:09 PM »
The delaware cars run on a 6300 rev limiter and yes they are checked in tech. My other question would be what tires does everyone run on? At delaware we are on the hoosier treaded tire.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=7753.msg46915#msg46915
Offline rossevans30
« Reply #19 on: July 10, 2008, 11:50:47 PM »
"Hoosier treaded" I don't think says much, their DOT seires, dirt tires?...
Kawartha and Mosport are 790's 7" wide 90 compound... I beleve that would be the same as Sunset and Varney, considering they share most rules.
Captial City, if anyone would come from that far is 890, 8" wide 90 compound...
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=7753.msg46924#msg46924
"If you spend as much time working on your car as you did online, you would be fast" - Stompin Tom Walters
Offline rossevans30
« Reply #20 on: July 10, 2008, 11:55:24 PM »
Sunset is the same as Kawartha. Stock lift is the Sunset rule, with Kawartha, Mosport (and maybe sunset) running the SL2 isky cam, in builts. Can run the rochester 2G with 50% rear and 55% left and I think 100 lbs lighter.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=7753.msg46926#msg46926
Offline Thunder6
« Reply #21 on: July 11, 2008, 07:39:14 PM »
We can run either SL1 or SL2 Isky cam. There are other cams available as well that are legal. No RPM limiters. I have run as much as 6800 rpm at BSW with a gear I didn't like much.
BSW runs a Hoosier core racing recap tire 8". I think Sunset tires are produced by the same recapper, but are a different tread pattern, like the old diamond back tire we ran at one time here.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=7753.msg46965#msg46965
