Author Topic: Bone Stock Build  (Read 17951 times)
Re: Bone Stock Build
« Reply #30 on: September 06, 2011, 06:20:20 AM »
The cage will be mounted to 1-1/2 X 3 X 1/8" wall Rectangle tubing. The sleeving was all done with .120 wall 1-1/2" as this particular cage is actually made with .120 wall. She is a bit heavy but it will be stiff for sure. We cut the cage with a bigass pipe cutter so it actually gives you a decent prep for welding. If you tack your sleeve before joining you end up with a nice open root with the sleeve as a backing plate. This gives you full penetration on your butt joint. This will be as strong as the original tubing was. If done correctly there is no need to worry about it being any less safe than any other joint on the cage
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=14028.msg97075#msg97075
« Reply #31 on: September 18, 2011, 02:54:29 PM »
I'm coming with some pics for yesterdays and today's work...hang on!! and does anybody have any Cavalier rims 5X100mm?
Stock rocker rail where we are going to reinforce for cage mount and side impact
Reinforcement rail in place along rocker rail welded to the floor and the rocker rail box section
Drivers side rail ready to weld in
This section where it is doubled up will be where the vertical bar of the cage will be attached to
This plate is welded to the the rear strut tower and a brace to the halo joint of the cage will go here
The cage will be going in next
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=14028.msg97560#msg97560
« Last Edit: September 18, 2011, 04:34:49 PM by jworacing »
Offline racingwrench
« Reply #32 on: September 18, 2011, 08:20:31 PM »
Offline bornagain
  • Chaos Car Driver
« Reply #33 on: September 18, 2011, 09:57:41 PM »
i got some rims offa 96 sunfire.  they shud fit... make an offer, also if u need any other parts let me know the cars just gonna go to scrap after i pull the cage as it has a blown engine now.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=14028.msg97603#msg97603
Offline bornagain
  • Chaos Car Driver
« Reply #34 on: September 19, 2011, 09:25:27 PM »
Offline bornagain
  • Chaos Car Driver
« Reply #35 on: September 20, 2011, 08:35:24 PM »
i think 14" but ill check and c for sure tmrww
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=14028.msg97749#msg97749
« Reply #36 on: September 25, 2011, 11:32:25 AM »
The vertical bar passes in to the rectangle tubing for increased resistance to shearing forces
That horizontal bar passes thru the fire wall to the strut tower
This bar holds the cage by bracing it against the rear shock tower
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=14028.msg97959#msg97959
« Last Edit: September 25, 2011, 03:32:44 PM by jworacing »
Offline Dougy109
  • Known by my brothers as 'Bones"
« Reply #37 on: September 27, 2011, 06:00:06 PM »
Not an expert, just tried it, refused to listen to conventional thinking, broke all the parts trying
« Reply #38 on: September 27, 2011, 09:11:23 PM »
We welded the roof back on it last night but couldn't do much cause of the rain. We gunna go back at it tomorrow
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=14028.msg98058#msg98058
« Reply #39 on: October 09, 2011, 12:15:53 PM »
This is one ugly car
The filler panels on the windshield area are so we can utilize lexan we had kicking around that wasn't quite big enough
Seat Mount
The dash cluster is required or the car doesn't run I'm told something to do with theft system
Right side door welded back on
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=14028.msg98329#msg98329
« Reply #41 on: October 10, 2011, 06:51:30 PM »
THis car is for sale and we're asking $1200 for it. if you are interested give me a shout
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=14028.msg98374#msg98374
« Last Edit: October 10, 2011, 08:13:30 PM by jworacing »
Offline Dougy109
« Reply #42 on: October 13, 2011, 05:38:21 AM »
« Reply #43 on: October 13, 2011, 09:45:34 AM »
I can't race due to fiscal restraints...meaning I'm broke. I'm gunna sell the car off and maybe build another for next year. Perhaps at that point I can purchase the necessary equipment to be able to compete. Sad but true :(
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=14028.msg98439#msg98439
Offline streetstocker33
« Reply #44 on: October 13, 2011, 10:29:34 PM »
what's missing? there isn't much to them, can't be much missing lol what's left? we might have stuff.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=14028.msg98455#msg98455
