Author Topic: Late-Model - Crate Engine PROGRAM  (Read 2249 times)
Offline LMS-QUEBEC
    • http://www.racingspectator.ca
« on: November 04, 2006, 11:16:36 AM »
CRATE ENGINE PROGRAM FROM WEST CARLETON NOW IN HIGH GEAR: NOV 4/06
In an effort to take a lot of the questions out of the cost of the crate engine program, Larry Aslagsen, owner of West Carleton Automotive the official crate engine headquarters for Capital City Speedway, has made that information available to everyone right here on this web site. This means that everyone knows what they are paying, as well as what everyone else is paying, what everything costs and what you get for that.  And in an effort to make this program as economical as it can possibly be Larry has come out with what I believe is rock bottom pricing,, and I have asked around. Larry will also make it possible for teams that have the ability to get their crate engine directly from a dealer to do just that, whether it be in a full blown advertising deal that someone might be able to do on their own, or and out right purchase directly from the dealership. I don't think this could have been made anymore racer friendly that what West Carleton Automotive is offering. This introductory cost which I believe is much more than competitive with any of the other shops that are qualified to do this engine, and is for the 2007 racing season only. The crate engine program is the best thing that has happened to Late Model Racing in my opinion and I believe we will see a large increase in this type of cars at our track over the next couple of years.
http://www.capitalcityspeedway.ca/print%20pages/crate%20motor%20cost%20sheet.htm
WEST CARLETON AUTOMOTIVE LTD
2120 Kinburn Side Road , Kinburn , ON . K0A 2H0
Phone: 613 832-2120. Email: larrywca@istar.ca
ACT – 350 CRATE ENGINE
1          24502609        GMZZ4 CRATE ENGINE ASSY
1          WC 10171       ENGINE STAND
1          WC 10123       LIFT PLATE
1          21313S            MOROSO CT OIL PAN
1          23418              MOROSO STEEL TUBING PICKUP
1          M55HV           MELLING OIL PUMP
1          42328              MANLEY HD PUMP SHAFT
1          21-900             CANTON FRONT COVER & BOLT KIT
1          9-3145             CLOYES TRUE ROLLER TIMING SET
1          ARP                CAM BOLT KIT
1          TCS-45121     FRONT COVER GASKET & SEAL KIT
1          1347101          ARP ROCKER STUDS
1          9976816          CRANE HEAT SINK ROCKER LOCK NUTS
1          CH1B-221S    BHJ HARMONIC BALANCER
1          CH900-20       BHJ BILLET TIMING POINTER
1          3206                BALANCER BOLT & WASHER
1          M4891             CARTER FUEL PUMP
1          11986              CRANE FUEL PUMP PUSH ROD
1          3719599          FUEL PUMP PLATE & GASKET
1          22-570             CANTON BILLET OIL FILTER BYPASS
1          68760              MOROSO VALVE COVER BREATHER KIT
2          36204              VALVE COVER BREATHERS
8          NGK                SPARK PLUGS
1          992869            GM BREAK IN LUBE
- LABOUR
INSTALL REPLACEMENT PARTS AS PER ACT SPECS.
DEGREE IN CAMSHAFT
BLUEPRINT HEI DIST – VERIFY ON SUN TESTER
DYNO ENGINE WITH 2 HR. BREAK IN
SUPPLY FUEL – OIL – FILTERS – GM EOS
SET UP FUEL CURVE  -  SEAL ENGINE
TOTAL PARTS & LABOUR - $6,995.00 - PLUS APPLICABLE TAXES
THE SAME PARTS & SERVICES ARE AVAILABLE TO A CUSTOMER SUPPLYING NEW 24502609 ENGINE.
DYNO & SEAL ENGINE - $2,450.00 - PLUS APPLICABLE TAXES
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=5623.msg21611#msg21611
