Author Topic: Thundercar Gear  (Read 4641 times)
Offline smokinjoe00
Re: Thundercar Gear
« Reply #15 on: August 03, 2008, 03:33:25 PM »
thats all we race at sauble is the th350 in 1st gear>>ive blown one up in 10 years>>
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8020.msg49494#msg49494
Re: Thundercar Gear
Offline ford93
Re: Thundercar Gear
« Reply #16 on: August 03, 2008, 03:39:49 PM »
I've seen guys at Peterborough run in 1st gear for years without hurting t350.
The guys at Ottawa told me a couple of years ago the they had a rash of  t350's blow up in 1st gear. (maybe cause the track is longer and the rpm is  held longer????)
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8020.msg49495#msg49495
Offline rossevans30
Re: Thundercar Gear
« Reply #17 on: August 03, 2008, 03:44:02 PM »
I haven't taken a 350 apart, but if I am harming 1st gear, will that also harm second?? Same bands and clutches?
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8020.msg49497#msg49497
"If you spend as much time working on your car as you did online, you would be fast" - Stompin Tom Walters
Re: Thundercar Gear
Offline bakstreethero
Re: Thundercar Gear
« Reply #18 on: August 03, 2008, 09:44:12 PM »
I was told that if you called ahead and let them know you where coming they'd have a "tow" cheque of $50 or something like that for you. I heard it from a mini guy who towed up last month for that invitational, it's worth the call.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8020.msg49520#msg49520
