THE 16TH ANNUAL AUTUMN COLOURS CLASSICOCTOBER 10th, 11th & 12th 2008
The Largest Race Event in The Province
NOTE: ALL CARS MUST RUN SOME TYPE OF MUFFLER
LATE MODELS 108 LAPS * $2,500 To Win, $250 To Take The Green $14,000 Purse
* Home Track rules and weight penalties apply
* Exceptions – Base weight
2,900 lbs for 10 –1 on whistler
50 lbs for compression – (max 10.9 on whistler)
25 lbs for small multi disc clutch.
* 400 Hp Crate engines – 2900 lbs
* 355 Hp Crate engines – 2800 lbs with 4 barrel, 2750 lbs with 2 barrel.
* 75 lbs fuel allowance after feature only
* Tires 8” -Hoosier 980 & 960 permitted on left only (used 8” ACTGoodyear & 10” rims permitted)
LIMITED LATE MODELS 75 LAPS * $1400 To Win, $6,000 Purse, “B” Feature if necessary
3,100 lbs for 10 – 1 Built
3.050 lbs for 9.5 -1 Built
3,000 lbs for Crate
* 100 lbs penalty for headers on non crate engines
* 50 lbs fuel allowance after feature only
* Tires 8” Hoosier 980 slick – 960 permitted on left only.
THUNDERS 50 LAPS * $500 To Win, $3,500 Purse, 25 Lap “B” Features -$175 to Win
* Home Track rules apply
* Tires as per home track rules
* Base weight – 3,150 lbs minimum, 100lbs for fuel injection.
* Home Track weight penalties apply
OSCAAR SUPER LATE MODELS 50 LAPS OPEN WHEEL MODIFIEDS 40 LAPS * Home track rules and weight penalties
* $800 To Win
* $4,500 Purse
MINI STOCKS 50 LAPS * minimum base weight must at least meet Peterborough Rules – additional weight
penalties may be imposed to equalize the field
* Tires -No racing tires, must be DOT approved and cannot have a tread wear rating
of less than 200, H rating permitted. Falcon – Azena tire is allowed.1/8” tread depth
rule will be enforced.
* $400 To Win, $2000 Purse
* 2 -“B” Features if necessary
FOUR FUNS 40 LAPS * Home track rules and weight penalties
2,200 lbs 8/12 Valve SOHC
2,400 lbs for 16 Valve. DOHC, Multi Port
* Minimum 60 series tires speed rated S or T. No racing tires. tires must be DOT
approved and cannot have a tread wear rating of less than 200, A 1/8” tread depth
* $200 To Win
* $1,100 Purse
HURRICANE MIDGETS ******
TIRES AND FUEL AVAILABLE AT THE TRACK
BREAKFAST SERVED FRI, SAT & SUN @ 9:00 AM
PITS WILL BE OPEN THURSDAY EVENING FOR PARKING
FRIDAY SATURDAY SUNDAYPIT GATES OPEN 10:00 AM 10:00 AM 10:00 AM
GRANSTANDS OPEN 5:00 PM 1:00 PM 11:30 AM
TECH LANE 10:30 AM 10:30 AM 10:30 AM
PRACTICE & SETUP 1:00 PM 1:00 PM 11:00 AM
QUALIFYING /
MAIN EVENTS 6:00 PM 3:30 PM 1:30 PM
ADMISSION GENERAL KIDS 8 – 12 PIT PASS
FRI $20.00 $5.00 $35.00
SAT $25.00 $8.00 $35.00
SUN $30.00 $8.00 $40.00
WEEKEND $45.00 $15.00 $48.00
PLEASE NOTE: DRIVERS RUNNING MORE THAN ONE CAR WILL BE SUBJECT TO ADDITIONAL
REGISTRATION FEE FOR ADDITIONAL CARS
FOR FURTHER DETAILED INFORMATION PLEASE CONTACT:
JP JOSIASSE @ 705-743-5880 OR WWW.PETERBOROUGHSPEEDWAY.COM
CAMPING AVAILABLE $25 per unit -Thursday till Tuesday
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8465.msg55091#msg55091
