2013 Velocity RulesLLM 202 Valves add 25 Lb
Hoosier 8 “ 980 Tires only, Tires you start the feature on will be the tires you finish on only tire that can be changed is a flat, if tire is deemed not to be flat one lap penalty.
No wide 5, Coil over, 603, 604 motors or Small clutches.
All other Home Track rules
Super Stock/Thunder CarsTires 8“Towel City treaded only
All other home track rules
Mini StockMinimum weight is 2200 pounds including driver for all 2000 cc and larger engines and all Honda's.
Cars under 2000cc. weight 2000 lbs.
Nissan 240 SX minimum weight 2600lbs.
Minimum weight for DOHC engines start @ 2500 lb
No Racing tires all tires must meet 200 tread wear
Speedway reserves the right to adjust weight in all classes to tighten field please have lead with you and a copy of your home track rulesRace Format24 Cars LLM and SS/Thunder (28 Mini)
Draw number for heat starting position
Double heat format with inversion
If more than 24(28mini) cars attempting to qualify though heats, the top 18 earners are locked in, if there are ties or no points, it will be determined by finishing position of your first heat, the next six (ten mini) will come out of the consi.
Inversion will be a double dice roll for positions 1 to 12 and will be rolled by the top point’s earners in the heat races.
Steve Slaughter
Sunset Speedway
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=18607.msg109410#msg109410
