Author Topic: Sunset's new Time Trials Format....Thoughts?  (Read 4417 times)
Offline MarkDilley
Re: Sunset's new Time Trials Format....Thoughts?
« Reply #15 on: March 25, 2011, 08:30:45 AM »
I am not sure where is says there are no heats one class will time trial a nite and as far as the starting line up will go it will work the same as if there were heats off percentage so the car with the highest percentage will start 18Th and so on.
Mark
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=12982.msg91867#msg91867
Offline mikey
« Reply #16 on: March 25, 2011, 12:27:41 PM »
adds a whole new aspect to saturday nite racing trackside betting to see how many laps does it take the front five to catch and pass the rear of the field
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=12982.msg91871#msg91871
Offline AaronM 29
« Reply #17 on: March 25, 2011, 05:37:54 PM »
its worth a try i guess, i think it is gonna be a easy way for the fast guys to gain points were they might not get to the front in a heat.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=12982.msg91875#msg91875
Offline 240racer
« Reply #18 on: March 25, 2011, 06:49:35 PM »
It would make sense to leave points out of the TT, it's gunna be the same guys up front every time more than likely.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=12982.msg91876#msg91876
Offline charlie7
« Reply #19 on: March 25, 2011, 07:24:44 PM »
240racer is right, with open track ahead of them, the fast guys will always be in the top 3 or 4.
Im a little confused on this still, if somebody can clear it up for me thanks:
Do the time trials affect the racing for the night, or is it just for stupid pride like Barrie used to do?  Are you actually gonna GAIN anything from runnning a qualifying lap, or am I better to keep my car in the pit with a so called ``problem`` and go get a burger  ;D
I remember the last time Barrie did this, it started to spit a little bit, so I just puttered around at half throttle, and made a joke out of the whole thing, it was pointless.  ::)
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=12982.msg91877#msg91877
*the guy who never took a chance, never had a chance!*
48fan
« Reply #20 on: March 25, 2011, 08:56:15 PM »
That's what we like to see support for the speedway you race at  ::)
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=12982.msg91879#msg91879
Offline danno428cj
« Reply #21 on: April 04, 2011, 01:26:29 PM »
you will gain 16 points if you are the fastest. these points then go against your percentage so the fast guys will still start at the back.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=12982.msg92058#msg92058
Offline extrordinair
« Reply #22 on: April 04, 2011, 02:36:16 PM »
I agree with silverstone,as a racer it is awesome but as a spectator it is pointless. i will also say that not always the same guys will be up front in qualifying because even a slower car can turn a COUPLE of really quick laps !
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=12982.msg92062#msg92062
wider is better! i usta could!
