Author Topic: Basic toe settings  (Read 4076 times)
Offline bradburleigh
  • Next year, will be a fast year.
Basic toe settings
« on: September 15, 2008, 12:40:03 PM »
Does anybody know a basic setting for toe that will help me corner better? :-\ This is for a fwd weighing about 2500 pounds.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8460.msg55047#msg55047
Basic toe settings
Offline ace
  • Track Owner
Re: Basic toe settings
« Reply #1 on: September 15, 2008, 12:41:10 PM »
« Reply #2 on: September 15, 2008, 12:42:24 PM »
Offline Scott
    • the dizzy pub
« Reply #3 on: September 15, 2008, 12:52:20 PM »
Call Me Crazy But I love The3Tards
« Reply #4 on: September 15, 2008, 01:02:26 PM »
i am supposed to do this with both tires? 1/4th out on both?  :-X
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8460.msg55060#msg55060
« Reply #5 on: September 15, 2008, 01:23:54 PM »
NO tow is the difference between front and back of front tires, not measured from side to side.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8460.msg55070#msg55070
« Reply #6 on: September 15, 2008, 01:37:14 PM »
i know this. no need to worry i found the answer, will put it into testing wednesday.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8460.msg55072#msg55072
« Reply #7 on: September 15, 2008, 02:36:45 PM »
Offline Junior
« Reply #8 on: September 15, 2008, 03:11:16 PM »
Brad, I offerd to help you get your car to turn? you havent let me know yet when or where the car is? check your PM's
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8460.msg55094#msg55094
Offline polishprince12
  • 2010-2011 Track Champion
« Reply #9 on: September 15, 2008, 06:24:59 PM »
i usually set my toes on the floor and in order! thats why my mom made me wear shoes, so i would quit chewing my nails. haha
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8460.msg55207#msg55207
Offline MikeSmith
  • Mr.X
« Reply #10 on: September 15, 2008, 06:33:31 PM »
LMFAO...All i can say...
Cheers
Mike
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8460.msg55217#msg55217
Just Call Me...Mr. X
Offline Hardcore Racing
    • http://www.sprintprinting.on.ca/jtracing
« Reply #11 on: September 15, 2008, 06:33:54 PM »
Brad
This post is in no way meant to be cheeky or sarcastic.
I was at the track Saturday night but my car wasn't working so I did some lawn chair time.
I watched a few things which you never get to see (like how that new crx is even allowed to pass tech????). If you want to see what you need to do to set up your car look at that one and back it off about 300%.
What I did notice about your car is you have NO front right camber. Your front right tire folds over like a 4 fun car. If you hold a level line on your bottom of tire there  should be a space at the top of at least 1 1/2". You are riding on the outside of your tire which will create a push. I would say first thing to do would be get that camber in there. Your car is a chrysler product so I think you have movement in your shock which you can adjust along with drilling out the wholes at the top of your shock tower.
I also noticed that your car rolls over in the corner (the body weight). You need to think about getting your front right bigger and stiffer and make your rear left smaller.
Things you will need to look at:
- camber setting
- caster setting
- toe setting (1/4" should be good)
- tire pressure setting
- shock/spring
You should go to a place like Factory Direct and bought a laser temp gauge and you use that to check temp of tires after race. It should be close on the outside, centre and inside of tire. If not your tire is not laying flat on the track. You want as much tire surface on the track that you can get. The one I bought there was $30 (I know of people that bought the same one for $140). At the same time at least get yourself a good tire for the front right.
Lastly take up the offers of anybody that is willing to help but make sure you are not doing one of those blind leading the blind things. I have had a lot of bad advice from people that ran at the back of the pack every week. I would be taking up Junior on his offer and in fact if he wants to come over to my pit and fill my ear I would be up for that.
Good luck and if you need to borrow tow bars I have them at the track, if you would like to borrow the temp gauge I have it at the track. I am working on my engine this week but if I have it done and am out there on Wednesday drop by my pit and we can set or check out a few of those things.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8460.msg55218#msg55218
Harold - JT Racing - #42 four cylinder
2004 Sunset Speedway Track Champion
« Reply #12 on: September 15, 2008, 08:23:16 PM »
how many new polish jokes will come from this post? flmao
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8460.msg55241#msg55241
« Reply #13 on: September 15, 2008, 09:10:03 PM »
how did the pollock break his neck drinking water? the toilet seat fell on his head! how did the pollock break his finger? someone punched him in the nose.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8460.msg55248#msg55248
« Reply #14 on: September 15, 2008, 09:19:26 PM »
lmfao
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8460.msg55251#msg55251
