Author Topic: Calling all Delaware Late Models  (Read 1070 times)
Offline slapdown
« on: August 14, 2007, 07:21:35 PM »
I see on the Delaware schedule that the LM's have the night off on the 24th. Hope some of you guys could make the trip to the 100 lapper at Kawartha. I really want to see a good field of cars at this event and I'm sure a few Delaware cars will make the show a great one. Here are a few things you guys may need to know. Could some of you Delaware guys that read this board pass this info on to the other LM drivers this Friday?
WEIGHT
All weights include driver (no substitutes).
All cars using a “Built Motor” with a compression ratio up to 10:1 will weigh 8.25 pounds per cubic inch with a minimum weight of 2925 lbs.  These cars will be allowed 56% left side maximum.
Any car with a compression ratio of 10:1 to a maximum to 10.9:1 will carry an extra 50 pounds. (2975 lbs.) These cars will be allowed 56% left side maximum.
All cars using KAWARTHA / OTTAWA /ACT /  QUEBEC LMS CRATE MOTOR option will be allowed 57% left side maximum and will maintain a minimum weight of 2800 lbs.
All cars using Flamboro / Delaware (88958604) CRATE MOTOR option will be allowed 56% left side maximum and will maintain a minimum total weight of 2950 lbs.
INVITATIONAL EVENTS of 50 laps or greater will give a spent fuel allowance of 50 lbs.
Track scales will be considered final.
WHEELS
All wheels must be after market racing type wheels made of steel.  Wheels will be a maximum width of 8 inches, bead to bead.
Specified track tire mandatory on all 4 wheels.  Tires will be available at track
Any other details can be found at http://www.kawarthadowns.com/webpages/speedwayLATEMODELRULES.html
Any other questions call Derek at 1-705-939-8881 ex 206
It also may be helpful to talk to Robblee to see what changes he made. Like I said, he was extremely fast.
PAYOUT
1st $2,200.00
2nd $1,500.00
3rd $1,200.00
4th $1,000.00
5th $800.00
6th $700.00
7th $600.00
8th $550.00
9th $500.00
10th $450.00
11th $400.00
12th $375.00
13th $365.00
14th $355.00
15th $345.00
16th $335.00
17th $325.00
18th $315.00
19th $300.00
20th $290.00
21st $275.00
22nd $265.00
23rd $255.00
24th $245.00
25th $235.00
26th $225.00
27th $215.00
28th $200.00
 $14,305.00
Gates open at 3pm and practice starts at 5pm.
Again, hope to see some of you guys at KD. And bring some money for the slots LOL
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=6515.msg30162#msg30162
