Author Topic: Break-out rule  (Read 9539 times)
Offline Team 33
Re: Break-out rule
« Reply #30 on: April 12, 2010, 08:22:11 PM »
this is only an opinion for the breakout rule,,
Instead of a lap time why not all go to an MSD Box with a 5,500 RPM Chip so all cars are the same.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11138.msg80040#msg80040
Re: Break-out rule
Offline LMFAN
Re: Break-out rule
« Reply #31 on: April 12, 2010, 08:48:59 PM »
Hey Sid
We were thinking about going enduro could you sell us a hopped up MSD with a 5500 chip in it.
LMFAO
Just kidding good idea though
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11138.msg80041#msg80041
Offline Dougy109
  • Known by my brothers as 'Bones"
Re: Break-out rule
« Reply #32 on: April 12, 2010, 08:49:06 PM »
Already spoke to the track on the rev limiter idea, unsure if it got passed to the right people. It goes back to setup a little more and gears then. It will definitely help, but not stop all of it.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11138.msg80042#msg80042
Not an expert, just tried it, refused to listen to conventional thinking, broke all the parts trying
Re: Break-out rule
Offline shifty333
Re: Break-out rule
« Reply #33 on: April 12, 2010, 09:23:31 PM »
The enduro rule book should (in the definition of the division) be no more than 1 page, 1/2 the page for safety stuff the other 1/2 with one big word
STOCK
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11138.msg80043#msg80043
« Last Edit: April 12, 2010, 09:25:07 PM by shifty333 »
Offline stockcarfan
Re: Break-out rule
« Reply #34 on: April 12, 2010, 09:48:03 PM »
I Like the rev Limiter, it will stop people from running high reving create motors or at least make them less of an advantage.  But i am sure those boxes are not cheap which would be a problem.  STOCK   is a good theme for Enduros.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11138.msg80045#msg80045
Offline Wernham
Re: Break-out rule
« Reply #35 on: April 12, 2010, 09:57:20 PM »
The MSD box and rev limiter idea would cost the racers $30,000( $500 a car x 60 cars). The track could almost hire a full time enduro tech person for what it would cost the racers.  I think they need to get back to the root of the problem and start teching the cars better and catch the illegal suspension and engine pieces that are already illegal in the rule book instead of creating new rules
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11138.msg80046#msg80046
Re: Break-out rule
« Reply #36 on: April 13, 2010, 07:00:16 AM »
Offline BornAgainFan
Re: Break-out rule
« Reply #37 on: April 13, 2010, 07:43:58 AM »
How about this? Since it is soooo hard to detect interior engine modifications. Why not this?  No suspension changes that's right no suspension alterations. That includes adjusting camber or stager, last time i went to a car lot none of the cars came stcok with camber. No camber less speed in the corners. This brings us back to the better driver can win. one more thing, any other rules that are broken by a team no matter how small, will result in all prize monies being taken back. OUCH. Hit em where it hurts and they will start to play right, that's for shure. PS the only reason we have rules is because some people cheat.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11138.msg80050#msg80050
Offline Wernham
Re: Break-out rule
« Reply #38 on: April 13, 2010, 12:31:47 PM »
Can you put a rev limiter on a chevy HEI distributor? I don't think you can but I might be wrong. If you cannot your left buying a ignition box, coil, rev limiter, distributor and a wiring harness.  I think a $500 hit would kill alot of enduro teams, also how would you apply the same rule to EFI cars that run the 4 and 6 cyls?
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11138.msg80054#msg80054
Offline notingtolose
  • Chaos Car Owner/Driver
  • Im movin up in the world you just wait and see....
Re: Break-out rule
« Reply #39 on: April 13, 2010, 01:27:00 PM »
you can run a rev limiter with the hei im almost certain that all the competors in the street stock and trucks run them with limiters. and limiters aren't the way to go. what they need is a caster chamber cauge in tech and every time you go through they check. no more than 2-3 deg and 4- in of caster but that is just my opinion
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11138.msg80057#msg80057
If you don't like it TO BAD!!
Offline FromTheStands
  • No Soup for You
  • Wanna be Grand Poohba
Re: Break-out rule
« Reply #40 on: April 13, 2010, 03:14:41 PM »
A) Limit the caster, camber.
B) Check uppers, make sure they are stock.  Length etc.
C) Stock bushings everywhere, no prothane,etc. All rubber.
D) Stock sway bars, not stock appearing or late model with eyes welded on.
E) Stock wheel base and track width, no spacers
F) Equal rear axle spacers and springs rates. (Even equal front spring rates)
G) Equal ride height, side to side.
N.B. - the crates aren't the ones running high rpms. Its the builts that aren't wrecker salvage.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11138.msg80059#msg80059
Offline Wernham
Re: Break-out rule
« Reply #41 on: April 13, 2010, 11:06:04 PM »
Those rules are already in the rule book Fromthestands but they are not enforced.  I can remember back a few years ago when Brian Thomas (former tech guy) brought a old nova to the track one night and told the street stock guys that there suspension pieces and mounting point has to be idenitcal to the old nova.   He gave them a weeks grace then if memory serves me right a few guys got DQ'ed the next week and cleaned the class up a bunch.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11138.msg80073#msg80073
Re: Break-out rule
« Reply #42 on: April 14, 2010, 11:36:18 AM »
thats what they need to do is bring a stock camero and metric car and say if it ain't the same you better fix it or ur not gettin your money next time
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11138.msg80081#msg80081
Offline What?
Re: Break-out rule
« Reply #43 on: April 14, 2010, 01:31:40 PM »
V8 Cars - Single exhaust out let only - must exit behind rear tire.
           - No dual exhaust systems
           - Single outlet max diameter 2" (or even smaller if needed to slow the V8's down)
           - No significant exhaust leaks
Of course I have not seen current rules, but this could help the situation with out having to set any lap time rules.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11138.msg80083#msg80083
Offline ford93
Re: Break-out rule
« Reply #44 on: April 14, 2010, 01:57:28 PM »
this rev limiter works just fine
$90 USD
MSD Digital HEI Module with TCD
PN 83645
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=11138.msg80084#msg80084
