Author Topic: KOTH on You _Tube  (Read 4177 times)
Offline isopropyl
KOTH on You _Tube
« on: October 13, 2008, 04:21:42 PM »
KOTH on You _Tube
[youtube=425,350]26odU-CGGKQ.[/youtube]
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8848.msg59362#msg59362
« Last Edit: October 13, 2008, 07:58:42 PM by CanadianRacingOnline »
KOTH on You _Tube
Offline isopropyl
Re: KOTH on You _Tube
« Reply #1 on: October 15, 2008, 10:46:47 PM »
[youtube=425,350]V9pZalGV8Gk[/youtube]
[youtube=425,350]rrYWNd8P9pM[/youtube]
These are from Sunset Speedway.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8848.msg59611#msg59611
« Last Edit: October 16, 2008, 07:33:11 PM by CanadianRacingOnline »
Offline isopropyl
« Reply #2 on: November 07, 2008, 01:45:34 PM »
Found another vid. on streetfire.
Hope Venom will come up to play @ KOTH next year, now that he knows the track, great guy.
http://videos.streetfire.net/video/Ported-Eaton-03-Cobra-on_190627.htm
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8848.msg60785#msg60785
Offline 3-Wide
« Reply #3 on: November 07, 2008, 02:51:37 PM »
got some cool videos there.... I think next year..I'l make my KOTH debute on a few select nights, I got a 99 Dodge Dakota R/T with a 5.9L V8....so I should be somewhat..competive  :P..haha
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8848.msg60790#msg60790
"RaceTracks are my 2nd Home"
"I'm a Short-Track junkie"
« Reply #4 on: November 07, 2008, 03:05:31 PM »
Kyle, you gotta work on keeping it outta the ditch before u hit the track with it!
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8848.msg60791#msg60791
Offline JoeT
    • SPDA - Subaru Performance Drivers Association / Sport Performance Drivers Association
« Reply #5 on: November 08, 2008, 10:10:27 PM »
Might as well add to this.. LOL
[youtube=425,350]<object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube]
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8848.msg60877#msg60877
Co-Founder http://www.spda-online.ca
Bringing Racing to Racers
Co-Founder of the Attack Time Trial Series (ATTS) ( http://www.atts-online.ca )
Friend to Davenport Subaru, Fenwick Subaru, and Subaru Canada Inc.
Offline JoeT
« Reply #6 on: November 08, 2008, 10:15:02 PM »
Here's what it looks like from my friends point of view, when he raced against the Legacy.
http://media.putfile.com/King-of-the-Hill---run2
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8848.msg60879#msg60879
Offline isopropyl
« Reply #7 on: November 09, 2008, 06:04:59 PM »
Hey Joe after looking at this year and last year @KOTH why do you look faster last year??
Were you playing with us heheheh. Or were you just smoother this year.
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8848.msg60916#msg60916
Offline JoeT
« Reply #8 on: November 09, 2008, 09:20:01 PM »
Hey Jen,
It's all about the show, give the audience what they want (within reason)... We didn't really need to be that close to the wall, right... tee hee, but it does add to the enjoyment factor.  Honestly, the first part of the year was a mess, new suspension, new turbo, different maps, different power delivery all added up to the "getting used to" the handling.
Notice, once we fixed the coil over / bumpstop scenario, things all of a sudden got super smooth with much less oversteer and more neutral handling.
The video with the 2008 red WRX had a tiny turbo on it.  Basically a modified TD04, just like the one in your car now.  Super quick spool up, but it ran out of breath up top and it was no use running any length of time above 5500 rpm.  The last video I posted, was a different turbo as well, it was a VF23, only 30 HP more than the TD04 but gobs and gobs more torque, over 320 Lbs ft of torque.
This year, I ran with a modified TD05 with a 6cm turbine side, it produced 370 WHP with similar amount of torque, but the problem with that was, the hot side was too small and restrictive resulting in high EGT's.  I've got an 8CM hot side now going into the car which should produce the same amount of power, maybe 380 ish WHP, but it'll run a lot cooler, and can sustain longer under power for Solosprint and Time Attacks.  Hope you come out to play on those events, you'll get more than addicted.. LOL
So, it should be lots of fun at the KOTH for next year.. I think you'll be having lots of fun with your new toy as well..
Linkback: https://www.canadianracingonline.com/smf/index.php?topic=8848.msg60920#msg60920
